Farmall M's HOW SOO LIGHT??????
Farmall Boy
03-07-2003 15:21:02
How are they getting M's in 4500????? I need some tips about how to lighten up a '39 M to get it light enough to pull 4500. Right now it weighs 4740 and all we have done is take off belt pulley,belly pump and all hydralics,the lights,and rear cast wheels for pressed steel. ALL COMMENTS APPRECIATED GREATLY..... .....FB
TimC
03-09-2003 09:05:29
 Re: Farmall M's HOW SOO LIGHT?????? in reply to Farmall Boy, 03-07-2003 15:21:02
Rearend housing cover is about 100lbs or more isn't it?
miss joei
03-08-2003 10:39:35
Here's what we did, Changed pedestal, pressed steel wheels front and rear (minimum weight wheels), put car drag tires on front end (much lighter), aluminum radiator, removed alternator and fan and hub assemblies, installed electric fan (not for weight for power), removed belly pump and pto shaft, removed all the trinkets, changed air cleaner, cut the tires, and we run 1/2/ tank of gas. Note, our club allows us to run with cut tires, probally took off 60 - 65 lbs. of rubber. Also we both went on diets. We are now well under 4500.
Farmall boy
03-08-2003 12:07:42
 Re: Re: Farmall M's HOW SOO LIGHT?????? in reply to miss joei, 03-08-2003 10:39:35
what are the "trinkets"...and what kind of
pedestal are yah runnin?????we jus put a 560 under
ours and haven't weighed it yet....and what kind
of tires are you runin??we are runin some 14.9's
wich should be pretty light...oh yeah we runnin an
aluminum tank too
ferg farmalls
03-19-2003 17:42:00
 Re: Re: Re: Farmall M's HOW SOO LIGHT?????? in reply to Farmall boy, 03-08-2003 12:07:42
after getting them this light are you winning.we have some m,s running in 4500,but my super H will beat them 4 out of 5. we pull on a 4.5 speed rule.
NO it dosen,t have a stroker. 175 ci-30% rpm
bob
03-08-2003 07:00:31
do even have a gen or charging system
G Taylor
03-08-2003 06:15:37
Plastic fuel tank holding a couple of gallons, light weight aluminium rad and electric fan. Open the excitation circuit on the charge system while pulling. Saves power from turning the fan and charging.
bob
03-08-2003 05:39:16
I have done all of these things plus a little more
and I am only down to 4700. to run in 4500 you have to get down to 4350 plus driver. So there must be more things you can do. trans cover?
Donnie
03-08-2003 03:45:31
Get you a narrow front pedestal off of a 656 International. The bolt pattern is the same as an M and it will have press steel wheels. It is lighter than a 560 and has a shorter stance. Take the breather system off and run some type of dry element. Ether make a home made draw bar or get one off of a H.
NO BULL!
03-08-2003 01:17:27
Around here (ILL)I have seen 2 M's in the 3500 Class but they still lost to a good H!
old fart
03-08-2003 00:34:38
What about narropw front versus wide front, is there much weight difference?
Mike706
03-07-2003 19:48:22
This is pry pretty obvious but only run enough gas to get down the track and off it. Again its obvious but noone has said it yet
hpuller
03-07-2003 16:23:52
You can pull out the pto and cover the whole in the back. You can use a lighter air cleaner. Drain a few gallons of oil out of the rearend. You could also use welded on axle plates instead of hubs.
Slo
03-07-2003 16:30:29
 Re: Re: Farmall M's HOW SOO LIGHT?????? in reply to hpuller, 03-07-2003 16:23:52
Put pressed rims on the front also. You can use a lighter front pedestal, such as a C. Look at the type of seat suspension you have. Might be able to save a few pounds there.
Jerry
03-07-2003 17:23:41
 Re: Re: Re: Farmall M's HOW SOO LIGHT?????? in reply to Slo, 03-07-2003 16:30:29
Some of the guys remove some of the material in the belly of the tractor under where the hyd. storage tank is.
Lite M
03-08-2003 17:00:48
 Re: Re: Re: Re: Farmall M's HOW SOO LIGHT?????? in reply to Jerry, 03-07-2003 17:23:41
Had a 39 M very, very competitive in 4500,5000 stock front,sheet metal,fuel tank,fenders,18.4 38 tires,steel rims,homemade hitch,3 70# weights,5 gal.gear oil,5 gal.gas,with 180# driver 4500#s. I do not see the problem.
