Mta
red brand
03-07-2003 16:14:48
does any one know if you can weild the gears together in a ta to stay in the low side all the time.my ta is out.wondering if this can be done.tight budget....thanks
Donnie
03-08-2003 03:38:27
 Re: mta in reply to red brand, 03-07-2003 16:14:48
9 Times out of 10 it is the ramp and rollers that are bad. Like the fellow said in pre post, It's fairly cheap to fix but alot of work. Also check to see if the TA clutch is not bad and thats not slipping. I've seen the ta presure plate lose a finger and not let it ingage. There is a plate on top of the ta housing that you can remove and see the clutch and pressure plate. Hope this helps.
randy hall
03-07-2003 20:57:54
the planetary gears only turn when the ta is engaged.
tazfarmer460
03-07-2003 19:58:26
My t.a. started slipping in the low side. All it ended up being was the rollers in the planatery. You can't hardly tell there is a flat spot on them but it doesn't take much to make it slip. Only cost about 10 dollars in parts but alot of work to fix. Good Luck.
E J
03-07-2003 18:40:55
I think if you weld the planet gears together and leave in direct it will work.Hope some one else reply's to this with more help.
