Off subject no responses in truck forum
farmall man
03-09-2003 16:57:10
I have a 77 ford f150 4x4. I have rebuilt the 351m with a clevland crank(stronger crank than the m's) bored it out .030 with keith black flat top pistons. I have also put in a good cam and it has headers going through flowmasters. I've finally got the money for a 4 barrel carb and intake. any suggestions. i think ive narrowed it down to a edelbrock 600 maual choke and performer intake or a holley 650 duoble pumper and a weiand intake. Any suggestions.
ff316
03-10-2003 19:05:00
 Re: off subject no responses in truck forum in reply to farmall man, 03-09-2003 16:57:10
I would use a double plane intake like the Performer. Edelbrock makes a good intake, but I have heard of people having trouble with the carbs. I would go with a Holley, or one of the "Demon" series of carbs, which are manufactured by a guy who seems to have all the Holley bugs worked out. I wouldn't use a double pumper, "Double Pumper" means you go to the gas station twice as much :) Vacuum secondaries seem better for street use. Double pumpers are also a lot more $ new, about 150.00 more than vacuum 2nd as best I remember.
Good luck, Fireman
tim
03-10-2003 11:05:36
holley is tops in my book but that edelbrock is decent too.one thing to consider is the edelbrock doesnt have a power valve that can rupture like a holley.(but most new holley's may have a check ball in the power valve circuit to protect it from back-fire ruptue.)
joecool
03-10-2003 08:57:51
you didn't say what size cam or if auto or stick. Are you using truck for everyday or pulling? My opinion, for everday driving, go with vacuum secondary. I would use 750 holley vacuum secondary. Better carb than either you suggested, better fuel mileage than double pumper and works better on 351. I don't know of ford forum, but have driven trucks like you are building.
Gman
03-09-2003 18:36:49
Farmall man I've used the performer intake with a quadra jet(GM) sounds like you got a handle on things except($1.90 a gal. Fuel) go for it. Gman
JDman
03-09-2003 17:51:03
Try Ford truck enthusiasts board. More information there than you can dream of on Ford trucks. I got there from search of Ford.
