450 head ?
TL
03-10-2003 14:38:33
I needed a head for my super m and found a rebuilt head for a 450.It's on now but what about the oiler tube?the one for the super won't work on this 450?The m had oil fittings on both ends to allow for the tube.this 450 head only has 1 fitting.Sure need some good advice.Thanks for any help
Wide Front SM Puller
03-10-2003 18:52:05
 Re: 450 head ? in reply to TL, 03-10-2003 14:38:33
I had the same situation, I was told to just put a brass fitting on it, it was just a breathing tube and did not have to be connected to the oil bath air cleaner. I was told this by a former IH mechanic who now pulls with an M. I have had no problems since I did this.
TL
03-10-2003 19:24:05
 Re: Re: 450 head ? in reply to Wide Front SM Puller, 03-10-2003 18:52:05
I am having trouble with the oiler tube under the valvcover,it has a small hole that provides oil for the rockers.
03-11-2003 04:11:13
 Re: Re: Re: 450 head ? in reply to TL, 03-10-2003 19:24:05
Just put in a brass fitting on the head .without capping it off, I get plenty of oil on the rocker arms without the tube. Crank it up with the valve cover off and you will be able to tell if you are getting enough oil on everything.
Farmall Boy
03-10-2003 14:44:00
isn't that the tube that is hooked up to the oil bath air cleaner?
TL
03-10-2003 15:10:06
 Re: Re: 450 head ? in reply to Farmall Boy, 03-10-2003 14:44:00
The tube for the oilbath was hooked up to a fitting on the outside rear of the head.the 450 oilbath is hooked to the valve cover I think?
