D17 Puller Motor
Bruce
03-10-2003 17:39:08
How much can i bore the sleves in a d-17 gas. Or do i need to go to a differnt sleve all togather. Also i was planning to stroke it to 5.125 using supper c farmall rods. Am i on the right track? Thanks to all for your help. Bruce
WC Builder
03-24-2003 19:57:38
 Re: D17 Puller Motor in reply to Bruce, 03-10-2003 17:39:08
sorry that I didnt reply sooner As for the piston Question Im sorry that I didnt explain, We use a J&E piston that is designed for a drag racing chevy motor Like a bored out 502. If you need the part number I have it somewhere J&E does stock these pistons so you can just call and get them. We do machine the block to accept the sleeves, you will have to turn the outside of the sleeve down just a bit. On the motors aver 5 7/8 stroke we start filling the blocks with hard block to add some strength. you will want to run a copper head gasket from Lubboc Gasket. we also run a dry deck to prevent water in the cylinders. we also bore the slevees alittle. But be careful any stroke over 6 creates a high rod angle.
ferg farmalls
03-19-2003 17:34:27
you won.t know unles you try it.its only money.
Allis Puller
03-11-2003 16:59:02
Another place you could check out is rosspistons.com, they custom make sleeves and pistons. just an idea.
wc builder
03-10-2003 18:06:29
start with a set of sleeves out of a 466 cubic inch deere motor (4440, 4650, 4250 etc.) bore the sleeves to accept a big block chevy piston, for rods get a set out of an H farmall they are a little longer than a c rod, and are offset and stronger than a c rod. with the crank any place between stock and 6 1/8 is optional when you get over 5 7/8 you will run into some major cam and pan rail work
G-MAN
03-14-2003 05:14:23
 Re: Re: D17 Puller Motor in reply to wc builder, 03-10-2003 18:06:29
What make and part number of big-block Chevy piston are you using that requires boring a 466 sleeve to fit? 466 sleeves are 4.56 inch bore, and stock bore for a 454 is 4.25 - .256" smaller than the 466 bore. I looked in several performance catalogs and can't find any big-block Chevy pistons that are available a quarter-inch oversize. I don't believe the 502 crate engine even has that big of a bore. What type of head gasket are using? Are you machining the step off the top of the sleeve? How are you sealing the sleeves in the bottom of the block? Please fill me in, as these sorts of projects interest me.
acwc
03-14-2003 05:08:03
How big can you build a WC motor?? Is it possible to get over 400 cu.in. in one??
To wc builder
03-11-2003 16:30:25
Do i have to machine the block to recive the john deer sleves. Thanks Bruce
WC Builder
03-11-2003 21:35:11
 Re: Re: Re: D17 Puller Motor in reply to To wc builder, 03-11-2003 16:30:25
Yes
PS
03-10-2003 17:47:30
I talked to a guy at work abuot what i was thinking and he called what i was doind " Thats basterdization of a good Orange tractor" Ya he bleeds orange. What do you think? Bruce
