Big cube farmall
confused
03-11-2003 15:07:10
from an earlier post about a big bore m there was a Paul M. that stated they put 5.75" bore in M engines was this a mistake? The blocks are only 23" long.
NetForce
03-12-2003 06:32:48
 Re: big cube farmall in reply to confused, 03-11-2003 15:07:10
You would be supprised at the names Paul M. has used. Sometimes he is Stan. Some times he is DW. Go To Page 4 about Big Cube Farmall. Look a couple post down He is Ted putting down the the Allis. Look a little futher down. He is TCOB talking about Mr. Bear. Go figure? ERIC with square pistons? Check out the Internet address these post are coming from.
eric
03-12-2003 05:47:54
5.75 works with square pistons....still working on how to ring it/seal it
A.P.
03-12-2003 02:16:18
Maybe they swapped in a W9 motor. Actually it is most likely just a mistake in typing and they meant 4 3/4". The largest bore I've heard of in an M style engine is 5".
Regards,
A.P.
E J
03-11-2003 20:43:56
You stager the pistons in the block more room.
Flyin Farmall
03-11-2003 18:07:30
I've been wondering about that myself lately!!I just do not see any way!It must have been misprint,probally 4.75.
