Cheaters or not
Tractor Dan
03-11-2003 16:42:01
I was at a tractor pull with my farmall 350 diesel witch has a factory installed torque amplifier i was told i was not allowed to use it. any comments??? Also at the same pull i found a guy with a farmall H which had a c169 stamped on the side of the engine which we all know the H came threw with a 152ci engine and i called them on it well there were aloud to pull still come to find out the guy who owned the H was the one who threw the stink about my ta any comment???
ronald
03-14-2003 07:33:03
 Re: Cheaters or not in reply to Tractor Dan, 03-11-2003 16:42:01
On the C.I. stamped on his block, If you went to your IH dealer in the 60's and wanted a replacement block for your H you would get a 300 or 350 block as its replacement. On some club rules it say's you must use the stock block or its replacement so he may not have been cheating, It depends on how the rules are stated..
Bone Stocker
03-15-2003 14:14:12
 Re: Re: Cheaters or not in reply to ronald, 03-14-2003 07:33:03
Does anything in "writing" from Harvestor or Case-IH exist to back that up? Ken Updike and Guy Fay say no. Does sound logical that they wouldn't keep making the old block when the newer one was basically the same and interchanged. I'm sure the H and M part numbers were discontinued before the supers and letter series. Whether the older part number was actually replaced with the newer one is a very good question. I'd be interested in any more information you might have on that.
Bone Stocker
03-12-2003 14:35:21
Well how'd your 350 diesel do against that mighty 169 cid H Dan? Could you have beaten him if you'd pulled that TA?
Bone Stocker
03-12-2003 21:02:43
 Re: Re: Cheaters or not in reply to Bone Stocker, 03-12-2003 14:35:21
I hear ya! Sometimes that high horsepower doesn't pay off. It's the fellow who pulls 2 or 3 times a month and figures out his set-up that you have to worry about. The horsepower thing is over-rated. If a plain old M can spin 18.4x38s in second and he's within the rules who cares? He's still got to out-pull you. Stick to the classes where you have ample power and concentrate on putting it to the ground. You'll be surprised how well you do against those stripped and souped up tractors. Sounds like a pretty scrappy 350 you've got there.
Tractor Dan
03-13-2003 04:50:12
 Re: Re: Re: Cheaters or not in reply to Bone Stocker, 03-12-2003 21:02:43
yeah the 350 pulls well i think one set of wheel wieghts and loaded tires it wieghs 6750 pounds and at one pull i can pull over 15000 pounds
Dave
03-13-2003 17:07:52
 Re: Re: Re: Re: Cheaters or not in reply to Tractor Dan, 03-13-2003 04:50:12
Seems like a heavy 350.
Tractor Dan
03-12-2003 14:53:21
yes at a different pull they wieghted the H up to 7400 pounds and my 350d wieghs 6750 pounds and i did out pull him i have to give them credit they have put alot of money into that H and it does have power but it didnt out pull the stock 350
WHY DOESNT EVERYBODY USE C.O.A.T.P.A. RULES AND PUT AN END TO THIS CRYING AND COMPLAINING
03-12-2003 13:10:29
YE WHY,TELL ME DONT YELL IM RIGHT HERE!!!!
Chearters or not
03-12-2003 13:38:19
 Re: Re: Cheaters or not in reply to WHY DOESNT EVERYBODY USE C.O.A.T.P.A. RULES AND PUT AN END TO THIS CRYING AND COMPLAINING, 03-12-2003 13:10:29
C.O.A.T.P.A. and its dictator are the ones who invented the word CHEATERS in the tractor pulling world.
Job
03-12-2003 17:10:11
 Re: Re: Re: Cheaters or not in reply to Chearters or not, 03-12-2003 13:38:19
Who is cheating at coatpa and who is the dictator?
Cheaters or not
03-12-2003 20:47:44
 Re: Re: Re: Re: Cheaters or not in reply to Job, 03-12-2003 17:10:11
You must not pull coatpa,or you have been out of the country for the last 10 years or you are 1 can short of a 6 pack if you do not know who the dictator is.
Tom
03-12-2003 11:30:53
Oliver shows press steel wheels in their parts books for both the front and the back. Oliver also had a power booster available on the 770 and 880 models.
I don't care if everyone is allowed to shift or not as long as it is all the same. Some people think they can shift between gears without a power booster or TA, so if it is going to be allowed for some then the others should be able to grind gears too. 2 cents
Jack
03-12-2003 08:27:59
I don't have T/A but don't mind pulling against people who use them.What makes some scratch thier heads is a plain ole M spinning out on a power track with 18.4 38's in second gear in FARM STOCK,yeah right!Can you say stroker much?
hmmm
03-12-2003 08:08:08
obviously that guy didn't want to get beat. he had an IH himself that was illegal with that engine. The regular H engine can be bored to accept the sleeves to make it a C169 without much trouble, but the block was illegal.
JD boys don't like the TA because they didn't have one, and they are just upset because mother deere manufactured antiques right up through 1959 when everyone else was making modern (6-cylinder) equipment. Boo hoo for JD green.
put put
03-13-2003 19:13:52
 Re: Re: Cheaters or not in reply to hmmm, 03-12-2003 08:08:08
Didn't deere make a 2 cylinder thru 1960 and the 4010's first year 1961??
kspuller
03-12-2003 08:07:32
You sound like a guy who shows up at a pull not knowing the rules then bitches all day about them.
Jerry
03-11-2003 17:25:04
Most pulls allow a tractor with a TA but you have to chose what speed you want to use. Why should you be allowed to down shift while others can't?
Mike706
03-11-2003 19:27:02
 Re: Re: Cheaters or not in reply to Jerry, 03-11-2003 17:25:04
Jerry,
Why shouldn't he be able to shift? If his tractor came from the factory with that part but that H didnt come from the factory with that engine he should've been able to use his TA and the other guy should been DQ'ed because he was clearly illegal. Honestly there is no common sense reason that he shouldnt be able to use it if his tractor came with it stock. Like someone else stated if you dont like it go out and buy a TA for your tractor. Then it will be illegal since it didnt come stock.
baystatebinder
03-13-2003 14:20:13
 Re: Re: Re: Cheaters or not in reply to Mike706, 03-11-2003 19:27:02
Should we also have to take spark plug wires off so we can be the same as a poppin johnny
Donnie
03-11-2003 17:42:17
Why shouldn't he be able to use it? It was a factory product. If you want to shift a T.A. BUY one. Just like alot of pulls won't let Farmalls pull with press steel wheels. They didn't come from the factory with them. So us Red guys are getting screwed both ways. It just amazes me how many Ollies and Deeres came from the factory with pressed steel wheels. My 2 cents. Thanks for the rant.
Glen
03-18-2003 12:39:05
 Re: Re: Re: Cheaters or not in reply to Donnie, 03-11-2003 17:42:17
Sounds like most of your clubs are letting things get too complicated. Our club has very simple rules. "BONE STOCK", just like it came from the factory. Very minimal overbores (allowing for an overhaul), no fancy pistons, T/A's must stay in one gear (which ever you started in), and there are some rules on hitch hieght and tire size. Our by-laws and rules allow for inspections if there is a protest. The club has been in existence about 7 years and we have had no major problems.
G-MAN
03-12-2003 05:24:20
I don't know about Olivers, but the fact is that Deere "A" and "B" tractors were available from the factory with pressed steel wheels, so I don't know why anyone would complain about the legality of running them. There's no way to determine what wheels a tractor came with, so nobody can accuse any one with stamped steel wheels on a Deere of cheating. Deere never built a hub to mount stamped wheels on a "G", so that's a different story in pure stock classes. Shifting the TA doesn't bother me, as most tractors I've seen do it usually spin out after shifting.
cause he can
03-12-2003 18:09:25
 Re: Re: Re: Re: Cheaters or not in reply to G-MAN, 03-12-2003 05:24:20
Why does a cat like his butt?...cause he can!
