Oliver front pressed steel
Doug
03-11-2003 22:07:35
What does it take to put pressed steel on the front of a Oliver 88 and how much weight can you lose? Thanks
Bill
03-12-2003 11:15:24
 Re: Oliver front pressed steel in reply to Doug, 03-11-2003 22:07:35
You have to change the front hubs on the front axles inorder to bolt on tin wheels. It isn't much work, but you probably want the weight up there anyway. I have a narrow front 77 with cast wheels in front and back and without adding any weight it will pick the front end up in the 4500 class.
Cody Adgent
03-13-2003 18:35:27
 Re: Re: Oliver front pressed steel in reply to Bill, 03-12-2003 11:15:24
I have a pair of 6 bolt hubs and bearings for a 77 or 88. They will save you about 175 lbs. I'll take $100 for the pair.
