Indexing spark plugs
Dave
03-13-2003 17:14:55
What is your opinion on indexing your spark plugs?Guy I talked to swore up and down that all he had done to his M was index the plugs. It was a strong pulling tractor that day. (he was carrying 5 trophys back to his truck, I only had 1)
Chances R
03-15-2003 18:46:33
 Re: indexing spark plugs in reply to Dave, 03-13-2003 17:14:55
It really helps with the chrysler flat heads.
IN Puller
03-14-2003 11:38:58
Pardon my ignorance, but what exactly is indexing plugs?
PLUG A LONG
03-14-2003 15:43:59
 Re: Re: indexing spark plugs in reply to IN Puller, 03-14-2003 11:38:58
WHEN you index spark plugs your are making shure that the gap of the plug is faceing the piston,now it may take a dozen or so plugs to get them all the same,indexing plugs make a big diff.on a motor that runs RPM.On a stock motor it helps when your running "HOT" or"HIGH" voltage and your GAP is wider.
Hope your not all confused now!
IN Puller
03-14-2003 17:29:48
 Re: Re: Re: indexing spark plugs in reply to PLUG A LONG, 03-14-2003 15:43:59
Thank you.
Dave
03-14-2003 17:04:29
Where exactly do you point the gap of the plug? Towards the intake valve, exhaust value????? ???
Funny Bunny
03-14-2003 04:38:40
Yea, right. That's all he did; had the Easter Bunny index those plugs for him.
laipuller
03-14-2003 08:23:00
 Re: Re: indexing spark plugs in reply to Funny Bunny, 03-14-2003 04:38:40
all joking aside, it does make a diffence, mine did run alot smoother and was alittle mor responsive. on a stock tractor i don't think that it would make that big of a difference. you wont waste you time if you do though
drag racer / puller
03-15-2003 07:43:08
 Re: Re: Re: indexing spark plugs in reply to laipuller, 03-14-2003 08:23:00
Indexing the plugs makes a big difference especialy when you are looking for that "little " extra . Things you guys for get ..... a bunch of little things here and there can add up. This is just one of them.
