Gonna try pulling a IH. WD-9 any help????
steve
03-15-2003 17:42:47
Im going to try pulling a IH. WD-9 and am wondering if anyone has any experience? Wondering how it will balance out & in what weight class?? Any other advice would be greatly appreciaped!!!! THANKS TO ANY & EVERYONE !! Steve
Joel H.
03-17-2003 19:26:33
 Re: gonna try pulling a IH. WD-9 any help???? in reply to steve, 03-15-2003 17:42:47
I pull a w-9 in the 6500, 7500, and 8500 lb. classes. Depending on which sled I pull on it can be a little nose heavy in the 6500 lb. class. I have the draw bar off,with a D-ring bolted to the cross bar. I have a weight bracket under the seat that holds a thousand lbs., rear wheel brackets with about 900 lbs., a front weight bracket and a belly bar. I haven't used the belly bar since I made the rear wheel weight brackets. I run 16-9-34" tires on the back. This year I am going to try 18-4-34" with smaller, lighter tires on the front. Any questions, post back. Joel
