G molin parts
Mike
03-15-2003 20:04:22
Where is the best place to buy parts for a G mm I want to make a puller and want more power out of it looking for pistons best head# where to place the hitch how high. so on and what is the stock hp on a G. Thanks Mike
Andy
03-17-2003 14:42:15
 Re: G molin parts in reply to Mike , 03-15-2003 20:04:22
If you are pulling stock, with a speed limet, a G is a great puller 7000-8500 without doing much besides wieght brackets and drawbar work. If you want pretty cheap upgrades you can run 4209 heads or 4210 heads with high octane gas and a LP manifold set.
Mike
03-17-2003 16:41:12
 Re: Re: G molin parts in reply to Andy, 03-17-2003 14:42:15
Thanks guys My tractor is a 48 g it was a gas tractor that was changed to a lpg by the factory I bought it from the orginal owner. I want to pull in farm stock i turnd up the govenor but not much and pulled it seems down on power. It has 110 cranking compession and will be rebuolt this next winter with bigger pistons and better heads I just want to cut my teath with it now Andy can you e-mail me about where to place the hitch and weight bars. also can anyone tell me what the best lpg regulator is to run on it and manafold and air valve. Pavilion1999@netzero.net Mike
E J
03-16-2003 17:18:30
Also another good source Everetts 744-755-7240.They pull many Minne's.
E J
03-16-2003 17:15:44
Keith Ededns
03-15-2003 21:38:34
Try welters farm supply ph 417-498-6496 good luck
Jerry
03-16-2003 04:56:53
 Re: Re: G molin parts in reply to Keith Ededns, 03-15-2003 21:38:34
Stock horsepower is around 75 h.p,
PISTON
03-16-2003 06:07:05
 Re: Re: Re: G molin parts in reply to Jerry, 03-16-2003 04:56:53
HAVE 1 READY TO PULL SAVE YOU A LOT OF WORK AN MONRY. GTB ON PROPANE DIV. 1 CAMPAIN FOR 4 YRS. IN HOOK MAZ. SEPT. 2002. 18-38 BOLT ON WHEEL WTHS.
