AC Roller rockers
Tractor Rod
07-16-2001 17:58:24
I need to know if any one is making roller rockers or if somebody can make a set For a Allis WC. Thanks Tractor Rod
Goldsburg
07-18-2001 07:06:24
 Re: AC Roller rockers in reply to Tractor Rod, 07-16-2001 17:58:24
Tractor Rod -
I have an existing design for the D17 rocker. You would have to determine if they are the same or would work. My design has 1.85 to 1 ratio with a roller tip. I will need the current rocker shaft stand sent with the order so that the centerline of the rocker shaft corresponds to the installed height of your existing valves. When I designed the original set, the head had lower than normal than installed valve heights, therefore my current stand design would probably be too short for your engine.
I also have high ratio roller tip rocker designs for other engines/brands. If I do not have a design for your engine, I would consider making a custom set derived from your originals.
Goldsburg
Brad Gray
07-16-2001 18:22:28
Can you provide a print or sample (stock piece)? When would you like to have them? I am not taking on any more work until around October.
Flyin Farmall
07-16-2001 21:18:27
 Re: Re: AC Roller rockers in reply to Brad Gray, 07-16-2001 18:22:28
there is a guy in southern WI who makes them for WC Allis,I'll find the number and let you know tommorow
