E-85 for pulling?
Troy
03-18-2003 21:24:41
Anyone using E-85(15% gas & 85% ethenol) in thier pulling tractor? It's 100-105 octane and burns real cool. I don't know the specific gravity though.
Doug in OR
03-21-2003 18:37:58
 Re: E-85 for pulling? in reply to Troy, 03-18-2003 21:24:41
I concur with these guys who say you need to burn more. E-85 has about 75% the energy per gallon as does gasoline. Laws of physics says that you need to burn about 30% more to develop the same hp.
fifthgeardeere
03-19-2003 07:08:48
Burning e85 in a >10-1 compression JD A. Don't notice any temperature difference. Do have to open load needle compared to e10/89 octane. Have ran e85 in a <13-1 G, but had to mix 1/3 with Cam2 to keep from pre-igniting. State Corn Grower Council will send you decals if you want to let everyone know you are supporting the industry.
sixthgearMM
03-20-2003 04:06:39
 Re: Re: E-85 for pulling? in reply to fifthgeardeere, 03-19-2003 07:08:48
The big gains would not be had 'til switching to Methanol. It has more oxygen in it than ethanol.
six and half gear Ollie
03-20-2003 12:38:29
 Re: Re: Re: E-85 for pulling? in reply to sixthgearMM, 03-20-2003 04:06:39
I agree with six gear MM. I don't believe youll notice much of a change until running Methanol.
9th gear M
03-21-2003 07:57:59
 Re: Re: Re: Re: E-85 for pulling? in reply to six and half gear Ollie, 03-20-2003 12:38:29
I've seen a 4-5hp gain on a stock M. You have to burn alot more e85 than reg gas to make the power though.
Where do you get a 9th for an M? I need to find one!
03-21-2003 15:57:23
 Re: Re: Re: Re: Re: E-85 for pulling? in reply to 9th gear M, 03-21-2003 07:57:59
9th gear M
03-21-2003 20:28:14
 Re: Re: Re: Re: Re: Re: E-85 for pulling? in reply to Where do you get a 9th for an M? I need to find one!, 03-21-2003 15:57:23
m&w 9 speed
