450 LP SPARK PLUGS
SMTA PULLER
03-21-2003 17:51:20
CAN ANYBODY TELL ME THE BEST SPARK PLUGS TO RUN, I have a 264 block with m&w 4.125 bore m&w turbo piston 5.75 stroke and m&w governor,and a 450 LP head, going to run 10%over on rpm,1760 Im planning to run in DIV-3.
Wide Front SM Puller
03-24-2003 17:00:28
 Re: 450 LP SPARK PLUGS in reply to SMTA PULLER, 03-21-2003 17:51:20
I have about the same setup, I use AC C-81 plugs at 30 degree gap(cold plug). It has not skipped a beat in about 20 pulls.
PHDM
PLUGALONG
03-23-2003 15:45:38
Autolite---3116 is a good all around plug,you can also try 388 or 386 depending on how your plugs look.
Trkr
03-21-2003 19:22:06
Have pulled the same setup as yours(except 4 1/4 bore 326)and have had very good luck with 3116 Autolites.
Farmall Boy
03-21-2003 17:58:26
Just not NGK we ran that in our 450 for two pulls and had them fouling out, but on a good note we got 2nd place on 3 cylinders HAHA!!!
