Stroking JD A
john
03-24-2003 06:14:03
When stroking a 2-cylinder, the back of the block must have windows cut-out for rod clearance. Do you have to take apart the transmission to do this? Any help or insight would be appreciated.
G-MAN
03-29-2003 05:23:25
 Re: Stroking JD A in reply to john, 03-24-2003 06:14:03
Cutting windows depends on how much stroke you want to add. If you're just adding an inch or so, I don't think it's necessary. I think most of the guys that do run windows just run engine oil in their tranmission, which holds up fine because they aren't used much.
2 cylinder
03-25-2003 05:51:23
I'm sure others will have their opinion, but from what I have heard first hand. No you don't, having said that, you will need to drain the transmission oil and do a complete flush of the transmission compartment.
