Cam shaft
Farmall
03-24-2003 15:28:49
Can anyone tell me if there is a difference in a 450 gas cam and a 450 lp cam ? I have had 2 used parts guy say there is are they telling the truth or ripping me off. One said there was a difference in dist. also something about the advances and weights.
randy hall
03-26-2003 17:00:28
 Re: cam shaft in reply to Farmall, 03-24-2003 15:28:49
the cams are the same. the advance springs in the distributor are different.
bud barenie
03-25-2003 19:39:37
go to a new i.h. dealer and have them look up the part number on a super m. or 400 or 450 of the exact same year !!! that will tell you !!!
i'm almost possitive the cam is the same, either way
Brian
03-26-2003 09:57:17
 Re: Re: cam shaft in reply to bud barenie, 03-25-2003 19:39:37
I would guess that they are different. The way the two engines work is very different and the timing for valve openings would likely be different. I think your one part guy that says the distances are different is probably right.
Wally G.
03-28-2003 15:30:08
 Re: Re: Re: cam shaft in reply to Brian, 03-26-2003 09:57:17
Best thing to do is get in the IH parts books and see if there is 2 different part numbers. You could also consider sending your cam out to be reground to a better profile for more torque or horsepower.
