Tire pressure
Tractor Dan
03-29-2003 12:32:35
i have watched quite a few tractor pulls on tv these people have put alot of money into these tractor excelent jobs restoring but hey dont pull well alot because not alot of experience but the biggest problem iv seen is they blow there tires up hard as a rock when i pull i let the pressure down around 8 1/2 or 9 pounds some times less the tire looks like it will come off the rim but get lot more traction than havin them real hard
Dave
03-31-2003 17:17:46
 Re: tire pressure in reply to Tractor Dan , 03-29-2003 12:32:35
Tire size, type of cut/no cut, brand of tire, how old, tread type, tread depth and especially the type of track determine what psi will do the best. There are NO set answers. We run tires from 13.6x38 stock to 18.4x38 cuts and have won with from 14 to 30# in the tires. GENERALLY speaking 14-18# seem best. We have a air supply on our semi so if we need air, it is available, or pump up tires at home and you can always let some out at the pull. The 8-9# seems low. There can be a 2-3# differance in air guages also. Good luck!!!!! !
BigRed
03-31-2003 13:14:38
My father would disagreee with you greatlyl, and quite frankly, so will I. I believe that the tires should give a little, but 8 or 9 pounds is way too low. You have to realize when those tires flex, you lose drawbar height, and that makes a big difference. Oh yeah, I'm not just a keyboard puller, I do the real thing and I'm pretty successful.
Tractor Dan
03-31-2003 13:58:58
 Re: Re: tire pressure in reply to BigRed, 03-31-2003 13:14:38
well i have a 35 or 40 horse power tractor that wieghs a little under 7000# and i have been able to pull 15000# with it
piston
04-03-2003 05:06:11
 Re: Re: Re: tire pressure in reply to Tractor Dan, 03-31-2003 13:58:58
bullshttttt ttttt ttttt ttttt ttttt ttttt.
BigRed
04-01-2003 19:07:45
Like I said, it is all a matter of opinion. I think alot has to do with track conditions and so on. I just thought I would give you my opinion.
phil
03-29-2003 18:51:02
How do you keep the wheels from slipping in the tire & tearing your tube at the valve stem?
