Powerstroke cuts off in the Rain??? Help!!!
Scott Williams
04-02-2003 07:11:20
2000 Powerstroke with 132K miles. When driving in rain, it occasionally cuts out while going down the road. A few times while idling at a stoplight, darn thing cuts completely off. ONLY HAPPENS WHEN IT IS RAINING! First, any ideas what it is? Second, how in the world am I supposed to find out what it is when it only happens once in a while?
Know this ain't a pulling question, but I'm not gonna be able to go to any pulls when it is raining till I get this fixed.
TRUCKPULLER
04-03-2003 16:21:44
 Re: Powerstroke cuts off in the Rain??? Help!!! in reply to Scott Williams, 04-02-2003 07:11:20
Park the piece of $hit in a fence row!
Super Steve
04-04-2003 18:52:35
 Re: Re: Powerstroke cuts off in the Rain??? Help!!! in reply to TRUCKPULLER, 04-03-2003 16:21:44
i agree go buy a real truck like a dodge
Masseypuller
04-03-2003 10:16:31
Scott -
As someone below had suggested, you should go to thedieselstop.com and check out the forums there.
I am a member also and feel that you will probably find that your CPS (Cam Position Sensor) is the culprit. They are notorious for cutting out while going down the road. Since they are located on the front of these engines, they would be unusually susceptible to being bombarded with water travelling down the road in a rainstorm.
Just a thought...
Masseypuller
Ray
04-02-2003 19:35:01
Do you have a VA box or power booster? I've heard
of guys having trouble after washing the engine
getting it started again,guess there not sealed very well.
Tractor Dan
04-02-2003 08:05:10
i have seen many fords have problems with the crankshaft sencor, i think about $75 and fairly eay to change not sure if thats your problem but it sounds like it dont worry dodge with cummins engine has lots of problems with the cranksencor as well hope this helps good luck ps the ford it 10 time the truck the dodge is
pickupman
04-02-2003 18:30:14
 Re: Re: Powerstroke cuts off in the Rain??? Help!!! in reply to Tractor Dan, 04-02-2003 08:05:10
and 10 dodges to equal 1 chevy
Jeff
04-02-2003 18:48:57
 Re: Re: Re: Powerstroke cuts off in the Rain??? Help!!! in reply to pickupman, 04-02-2003 18:30:14
Chevy?? What is that? Do they make a diesel?? :))
Jim (Mi)
04-02-2003 12:35:37
Yep, takes 10 Furds to = 1 Dodge. :>)
eric
04-02-2003 08:03:45
go to TheDieselStop.com sign up and post your question. more powerstroke info there than at any ford dealer. eric
