ford carb jets
eric
04-03-2003 19:05:55
I help a friend that owns a race car, we have different jets for different air temps and to adjust how the engine runs. I have a 960 Ford that I am rebuilding-restoring and was thinking of taking it to local tractor pulls, I guess that I'm just hp hungry. I put the engine back mostly back to stock. I have an 8n with electronic ignition in it so I know how it works. Any help would be appreciated.
Fruitfarmer
04-04-2003 16:23:59
 Re: ford carb jets in reply to eric, 04-03-2003 19:05:55
I pull with a Ford 960. Don't screw it up. You have plenty of horsepower with a stock motor. The challenge is to use that horsepower on the ground. Save your money and look for some good pulling tires. Play with air pressure and placement of weights.
eric
04-05-2003 18:43:06
 Re: Re: ford carb jets in reply to Fruitfarmer, 04-04-2003 16:23:59
I know most people don't like giving out their tricks, but if you could help me it would be great. I have 13.6 - 28 Goodyear Tires and am working on getting a set of rear pie weights. The tractor also has power adjust rims and a narrow front, I have a wide front that I can put on. Any ideas on were to add weight and how much were.
Fruitfarmer
04-09-2003 17:53:45
 Re: Re: Re: ford carb jets in reply to eric, 04-05-2003 18:43:06
Eric, Send me your e-mail address. bjarcher@epix.net
