How thin?
James Tierney
04-05-2003 11:51:48
How thin can you bore a wet sleeve (O-rings are in the block) before you start cracking sleeves. Tractor originally had 4.5 bore with 5" OD sleeve. Can I go to 4.75 bore safely?
TimC
04-08-2003 08:51:32
 Re: How thin? in reply to James Tierney, 04-05-2003 11:51:48
I have heard .125 wall thickness is about as thin as you want to go without some support. That may be thin if you are going to generate a great amount of heat (high compression) for long periods.
