Farmall A pullers
shaggy
04-06-2003 19:50:53
I was wondering if anyone that pulls A has ever had trouble with the drive shaft at the transmission? To me there is not much to the coupler is there a way to beef it up or is it okay as is? Thanks
Brown Dirt Cowboy
04-06-2003 20:31:53
 Re: Farmall A pullers in reply to shaggy, 04-06-2003 19:50:53
Shaggy I have been pulling a Farmall B which should have the same coupler as your A for about 6 yrs now with no problems. There is 3 of us around here with B's all set up about the same and as far as I know none of us have had a problem. Tom
shaggy
04-06-2003 21:27:59
 Re: Re: Farmall A pullers in reply to Brown Dirt Cowboy, 04-06-2003 20:31:53
I didn't think it would be to much of a problem but it doesn't hurt to check. What class do you pull in 2500? The lightest we have is 3500 and the olivers clean up there. Iam trying for a small class. Thanks shaggy.
Brown Dirt Cowboy
04-09-2003 09:00:17
 Re: Re: Re: Farmall A pullers in reply to shaggy, 04-06-2003 21:27:59
Shaggy I start at 2500 and pull up to 3250, have tried 3500 but that is getting to be a little much. A club here is doing away with the small classes this year and will start pulling at 3500 but we will stillbe able to get in plenty of pulling. Most of the competition here is from the small A-C's. I will have to fix my shifter also because it jumps out of gear but i use a tarp strap to hold it in. E-mail me and we will compare how tractors are set-up. Tom
GM
04-07-2003 20:23:54
I pull an A and I have to tie mine in gear with a piece of rope, "elsen" it jumps out.
cliff
04-08-2003 08:18:57
 Re: Re: Re: Re: Farmall A pullers in reply to GM, 04-07-2003 20:23:54
to GM remove your shifter and repair your shifter rod were the ball sits wen your in gear.
