Best tire size for John Deere G ?
JD720
04-07-2003 19:42:41
Going to pull in the 4 M.P.H class and probably some 3.5 M.P.H. classes.4500-5500 weight.Which is going to work best 18.4 X 34 or 18.4 X 38.Either one will be cut. Thank you
2 cylinder
04-08-2003 19:25:34
 Re: Best tire size for John Deere G ? in reply to JD720, 04-07-2003 19:42:41
16.9 x 38's work well for me on my JD-G in 5500lb. thru 6500lb. classes even against the competition using 18.4 x 38's.
Jack
04-09-2003 04:58:06
 Re: Re: Best tire size for John Deere G ? in reply to 2 cylinder, 04-08-2003 19:25:34
Thats what I am running,16.9-38 and they do very well and mine are almost as tall as 18.4 38's.Lack an inch.Good luck,Jack(TN).
puller
04-08-2003 16:08:46
go with the 38's. I've tried both and 34's suck.
Farmall Boy
04-08-2003 09:56:07
Well it really depends how much horse power you have...if hp. is a issue go with the 34's but if hp isn't an issue go with the 38's tractor will sit better and more ground speed if ever a gear limit....I got a ? for you...Do you know where I could get some good 16.9 by 34's ?????/ Thanx fb
