Degree 301IH cam
WI IH
04-09-2003 10:52:28
Does anyone have a Good method of advancing the camshaft on a 301 3 degrees?
Chris
04-09-2003 11:50:28
 Re: degree 301IH cam in reply to WI IH, 04-09-2003 10:52:28
Is it a stock or re grind cam?
WI IH
04-09-2003 14:13:57
 Re: Re: degree 301IH cam in reply to Chris, 04-09-2003 11:50:28
regrind 105 degrees on intake
Chris
04-09-2003 14:41:25
 Re: Re: Re: degree 301IH cam in reply to WI IH, 04-09-2003 14:13:57
If you are using a std. timing gear you can use an offset key way to advance or retard the cam shaft....
CHRIS
04-10-2003 19:39:29
 Re: Re: Re: Re: degree 301IH cam in reply to Chris, 04-09-2003 14:41:25
It works...top engine builders do it...currently using this in a 301...
WI IH
04-10-2003 08:06:51
I was just wondering if you have used this method
