35 unstyled A JD
Matt Wagner
04-11-2003 19:34:35
would my A even be competitive weights 4100lbs i bored it .125 and put aluminum custom high dome pistions and are cut back to the spark plug and put a cold gas manifold and i dynoed it and it had 48hp on the pto it has the brass carb on it runs beautiful just dont know if i would be competitive in the 4500lb class any suggestions would be great thanks Matt Wagner
Jeff
04-11-2003 20:35:54
 Re: 35 unstyled A JD in reply to Matt Wagner, 04-11-2003 19:34:35
Depending on several other things such as gear your pulling in,tires, and weight balance I would say you have the HP to be competitive in at least Stock class. Kinda the problem I am afraid I am going to run into this year is that in 5500-6000 I spun out instead of bogging down. had water in my tires then and everyone has said to go to a lighter class. Heck if I am spinning now I will surely do the same in 4500 right?
Farmall boy
04-13-2003 14:20:11
 Re: Re: 35 unstyled A JD in reply to Jeff, 04-11-2003 20:35:54
I would say you would be pretty competitive with all that weight your able to move around, we pull an M in 4500 and only have about 75lbs to move around(hard to balance)
