Dynometer without pto
Jason
04-14-2003 14:30:59
what type of dyno are you guys using without a pto, I've got a 36' JD A I would like to check. are you using a chassis dyno or what. thanks!
bryan
04-17-2003 16:04:37
 Re: dynometer without pto in reply to Jason, 04-14-2003 14:30:59
Hey Jason, Post you E-mail address and I can send you some pictures of a belt pully dyno. Thanks Bryan, I dont know how to paste a picture on this web site.
laipuller
04-14-2003 20:40:34
in the past at the show at portland in, i have seen a dyno fitted with a flat belt pulley, and have a shear pin in the end of it of some sort, maybe a splined shaft to attatch a pto to. if you are near there take a look at it, if not it is worth the trip there to see the show.btw they do have a swap meet some time in the spring not sure of the date
Gpower
04-14-2003 14:57:02
Most of the ones ive heard about, used a pto dyno, and made a setup so that you could use the belt pulley to run the dyno. Have to put some grip tape on the belt pulley to prevent slipping of the drive belt. Am not sure how accurate it is but seems to work well.
