4020 pulling clutch
Jason
04-16-2003 20:28:59
What springs work for beefing up the clutch in a 4020. Would 4630 ones work or does someone make heavy ones for pulling. Also what would be the best disc to use, and should I remove the pto if I am going to run 3000rpm.
karl
04-17-2003 21:04:56
 Re: 4020 pulling clutch in reply to Jason, 04-16-2003 20:28:59
pad
G-MAN
04-17-2003 16:03:53
Are you dealing with a synchrorange or powershift tractor? Powershifts also use a dry disconnect clutch that can slip in high-horsepower applications.
WTW
04-17-2003 09:56:27
Jason, A 4630 has a hydraulic type clutch (Perma Clutch), No springs in it to hold clutch plate engaged just hydraulic pressure. Use clutch springs for a 4320 as they are a little longer and stiffer. You could put one washer under the spring also . It will make a pretty stiff clutch pedal. The other thing you can do with these old John Deere dry clutches to give them a little more help is engage the PTO when you are going to pull with it as the pressure from the over center action of the PTO clutch is applied to the traction clutch. Good Luck, Dave W.
karl
04-17-2003 07:44:00
YOU can put a washer or two under the springs to have more holding power and put the pad disc in.
FRITZ
04-19-2003 19:21:14
 Re: Re: 4020 pulling clutch in reply to karl, 04-17-2003 07:44:00
Jason Ipull 4010 350 hp?+ -. Turns 4100RPMs,natural asperated. Run a stock clutch with a little help [crazy Ha]. Need help E MAIL.
Het Fritz?
04-20-2003 09:15:57
 Re: Re: Re: 4020 pulling clutch in reply to FRITZ, 04-19-2003 19:21:14
Is your 4010 a gas or desiel? What kind of Cubic Inches? thanks.
FRITZ
04-20-2003 11:21:12
 Re: Re: Re: Re: 4020 pulling clutch in reply to Het Fritz?, 04-20-2003 09:15:57
Propain 702ci
G Taylor
04-20-2003 13:07:42
 Re: Re: Re: Re: Re: 4020 pulling clutch in reply to FRITZ, 04-20-2003 11:21:12
How did you cram 702 cubes into that little gas block? Those pistons must be only 3/8" of an inch apart.
Fritz
04-22-2003 19:58:32
 Re: Re: Re: Re: Re: Re: 4020 pulling clutch in reply to G Taylor, 04-20-2003 13:07:42
G Taylor you want cram,how about 824ci.Have crank,rods and pistons, just missing 1/4 deck plate.1500.00 YES IT DOES FIT. [FROM IXPERIENCE]Selling do to rule change.
Jason
04-20-2003 08:00:41
FRITZ what is you email, also anyone have experien in putting 466 sleeves in a 404?
FRITZ
04-20-2003 11:23:35
 Re: Re: Re: Re: 4020 pulling clutch in reply to Jason, 04-20-2003 08:00:41
fritzjennifer1566@msn.com
Jason
04-17-2003 16:08:55
By pad do you mean ceramic or the standard disc. The tractor is a syncro also.
