Super 88 won't get up to pto speed.
Isaac
04-18-2003 06:03:40
I have a Oliver Super 88 that will not get up to pto speed on the dyno. It will only get up to about 450. I've tried to set the the rpm up on the motor and it sounds like it's going to fly apart but it still won't get up to speed on the dyno. Is it possible that the govener is not kicking in or the governor spring is bad.
ANTHONY TRAN
04-21-2003 11:01:51
 Re: Super 88 won't get up to pto speed. in reply to Isaac, 04-18-2003 06:03:40
Dear Sir/Madam:
We are a direct import/export company in Vietnam that specializes in selling used Japanese farm tractors. We export our tractors throughout the world. Our tractors are fully reconditioned and high quality tractors. We carry all kinds of tractors with brand names such as: Yanmar, Mitsubishi, Iseki, Kubota, Shibaura, Satoh, Hinomoto and many more… To satisfy our customers worldwide, we bought 4 giant warehouses on Highway 1 and Highway 20 in Vietnam to supply our customers with a large quantity of order. We also guarantee that our prices are competitive. We are seeking worldwide distributors for our tractors. Please let us know if you are interested to become our authorized distributor for our tractors. Please contact our representative office in California at 310-538-0724 or email: businesscenter@apcctran.com website: www.apcctran.com
Thank you for your time and we look forward to hear from you.
Sincerely,
Anthony Tran
President
Isaac
04-18-2003 16:56:45
Even if I put a tach on the moter it's still not up to stock engine rpm's.
jeff
04-18-2003 19:55:07
 Re: Re: Super 88 won't get up to pto speed. in reply to Isaac, 04-18-2003 16:56:45
The engine itself is not coming up to speed? If that is the case check to make sure all of the linkage is adjusted right and properly connected. I had that problem once.Can you move the throttle control at the carb and bring it up? If so then i would suggest going into the governor and checking it. I had one doing the same thing and once I took the gov apart I saw that the thrust washer on the backside of the drive gear was gone and had been for a while. The gear was undercut about an 1/8 inch or so and not letting the RPM come up. I made a bronze bushing to take up the space and it run great!
Hope this helps! Feel free the email me if you have any questions.
missery
04-18-2003 14:52:42
you sure you have it fully engaged?
Jeff
04-18-2003 12:13:57
Not sure if this has anything to do withit but does the PTo have a separate clutch to engage it? If so or something like one it could be slipping under load maybe.
Farmall Daddy
04-21-2003 08:21:59
 Re: Re: Super 88 won't get up to pto speed. in reply to Jeff, 04-18-2003 12:13:57
The Super 88 should be the same as the 88 as in having live pto. It may be possible for the pto shaft to slip in the gear box. Good Luck!!
