Automotive plug wires in JD G?
Matt B
04-22-2003 03:52:10
Has anyone run into problems using automotive type, resistor plug wires on an otherwise stock ignition system on antique tractors (especially JD 2 cyl.)? I've heard people say not to use them, and just stick with the standard copper conductor wire. Any thoughts/comments will be appreciated.
Thanks
Jack
04-22-2003 06:52:20
 Re: Automotive plug wires in JD G? in reply to Matt B, 04-22-2003 03:52:10
I have always used solid core wires w/stock ignition but went to the automotive wires w/my electronic ignition.
SHOCK IT TO YA
04-22-2003 19:45:42
 Re: Re: Automotive plug wires in JD G? in reply to Jack, 04-22-2003 06:52:20
YOU ALWAYS USE COPPER CORE WIRE ON THESE TRACTORS!!The wires used for automotive are to keep raido noise down,and how do you do that you ask?,,,by using a carbon inpregnated fiber cord,your loosing current to the plugs with these type of wires,,,why does my car run fine than you ask?,,,,because the motor is set up to compensate for this loss and you the common joe doesn't notice the difference.For the guy that is running the CAR wires with his tractor,switch them and reset your carb and timming,and HANG ON WHEN YOU HOOK UP!
Jack
04-24-2003 14:22:31
 Re: Re: Re: Automotive plug wires in JD G? in reply to SHOCK IT TO YA, 04-22-2003 19:45:42
I have 8mm MSD wires.They were extras off a friends car that runs in the lower 5's in the 8th mile.Stock cam stock carb,gas manifold,M&W.090 pistons and she's right close to 60 hp.I had used these wires thinking that a hotter coil and electronic ignition may make the solid core wires arc but I do still have the others.What about opening up the gap more than .040?Thanks
JDGnut
04-24-2003 15:12:00
 Re: Re: Re: Re: Automotive plug wires in JD G? in reply to Jack, 04-24-2003 14:22:31
I use the Taylor 8.5mm wires.. the the Ele pickup, with the Flamethrower coil... Small plugs with adpaters at .050.. No problems...
JDGnut
