Thinking of pulling
DanWV
04-26-2003 10:40:08
I am looking for a little advice from you seasoned pullers. I would like to start tractor pulling and would like to use either a farmall 560 or a farmall 560 diesel. Which would be the better tractor? I am aware that the diesel would be more expensive but would it be a better performer? Or would you say I am barking up the wrong tree with the 560? Would I be better off with an M or superM? Any thoughts would be helpful. Strictly red ones. Thank you in advance.
DanWV
max puller
04-27-2003 07:11:03
 Re: thinking of pulling in reply to DanWV, 04-26-2003 10:40:08
The M would be more versitale than the 560, if you going to pull with more than your local club, because of the year of the tractor, for a 560 is to new for many clubs. You can start cheap with the M in the lower class's and as you learn the tricks of pulling spend as you go. If your pulling a 560 go with gas unless your goal is to end up in the hot field class with a turbo motor. If you go with a 560 you can run a 301 motor from an old combine and biuld from there. Just my 2 cents have fun
Dave
04-26-2003 16:42:48
It depends upon the type of pulling you want to do,( how stock or hot and how deep your pockets are). In my book, it is hard to beat a Super M, (4cyl vs.6cyl...cheaper to hop up). You can start in the Div 1/farm stock classes for not alot of money and gradually work up the food chain, improving your tractor and your pulling knowledge. Much cheaper to get started with a 4 cyl gas than a 6 cyl diesel. Good luck and have fun!!!
