Farmall Head Gasket
FarmallHO
04-27-2003 05:32:47
Does anyone know of a off the shelf head gasket that will work with 4 1/4" pistons that come to the top of the bore in a Farmall M? The largest hole size I have found is a 450 and is 4 1/8". Thanks, HO
Earl S.
04-27-2003 20:41:01
 Re: Farmall Head Gasket in reply to FarmallHO, 04-27-2003 05:32:47
M&W always used the Victor # 3149 head gasket on there 4.250 bore 450 Ihc. Earl
306m-puller
04-27-2003 18:55:33
The stock gasket should work just fine as long as the back side of the fire ring does not go past the edge of the cylinder wall. I have 4.31 pistons in my M and still use the stock gasket. LM
farmallflogger
04-27-2003 11:23:46
The stock gasket should work with a 4 1/4 bore. Tme M-450 gaskets are the same.
