Boring and sleaveing a 70 block
JDBert
04-29-2003 20:00:47
Who sleeves two cylinder blocks? I was thinking of boring and sleaving my 70 gas block (which is already cracked in the bore) out far enough to sleave it to fit 730 diesel pistons. I know I would have to turn the piston tops down to get my desired compression ratio. What do you guys think, is this possible? Just tossing some ideas around. thanks Rob SWMN
G Taylor
04-30-2003 05:34:29
 Re: boring and sleaveing a 70 block in reply to JDBert, 04-29-2003 20:00:47
Why not go with the bolt in 6-1/2" plus powerblock instead of much fiddling and only go to 6-1/8. Have to go to at least 6-1/2" to gain any power. There are some awesome 7+ inch bore after market blocks out there too.
bigmotors
04-30-2003 03:22:08
You can bore a gas 70 block to 6.125
Yes, you will have to redo the pins, or cut the 730 rods and weld them to the 70 rod.
If your going to sleeve it, why not go big.
Drop me a e-mail, and I'll give you some numbers for redoing your block.
Good Luck!
JDBert
04-30-2003 17:51:43
 Re: Re: boring and sleaveing a 70 block in reply to bigmotors, 04-30-2003 03:22:08
BigMotors I'd like to talk to you but I need your email.
bigmotors
04-30-2003 21:39:35
 Re: Re: Re: boring and sleaveing a 70 block in reply to JDBert, 04-30-2003 17:51:43
debergrc@grinnell.edu
john r
04-30-2003 00:50:08
don't know if there is enough meat in the block for that. the 70 gas runs a 5-7/8 bore, the 720 is 6-1/8 may get by with thin sleeves. wrist pins would be bigger on the 720. could get right interesting.
