Div IV jd a
Hank
03-20-2001 17:28:52
What is you guys opinion on a 4000 or 4250 lb divIV 37a,can they compete with the higher rpm tractors or would it be a waste of time,i do have a powerblock for it if it would help.thanks Hank.
G Taylor
03-20-2001 22:00:35
 Re: Div IV jd a in reply to Hank, 03-20-2001 17:28:52
Div IV is a max airflow through the engine per minute for max HP game. The Deere's two massive cylinders are fed through one or two relatively long & small diameter passages. Made for low RPM torque & efficient combustion of fuel. High HP requires large dia/short length ports & lots of RPM.
Slo
03-20-2001 17:34:44
Be prepared to spend lots of money. It's possible, but a lot of work and money. A couple of Deere's did well in the open classes at Sigourney, but they are the exception and not the rule. Div 4 is much the same as their open class.
It's tough to compete with $20,000 motors on a consistent basis.
Hank
03-20-2001 18:06:20
 Re: Re: Div IV jd a in reply to Slo, 03-20-2001 17:34:44
What would be your suggestion for a little puller 3200 to 4250 range anything but a oliver,got to have something to shoot for.Was thinking a cockshutt 30 for something different.
Slo
03-20-2001 18:54:48
 Re: Re: Re: Div IV jd a in reply to Hank, 03-20-2001 18:06:20
Much as I hate to say it, a WC Allis is one of the best to compete with the Ollies. JD B's can do alright in speed limit classes, but fall short in the opens. Maybe a 101 Massey.
Slo
03-20-2001 18:57:06
 Re: Re: Re: Re: Div IV jd a in reply to Slo, 03-20-2001 18:54:48
And Farmall H's, too.
