Does anyone know when the ridgeland, WI tractor pull is?
Luke Olson
05-05-2003 08:57:25
I would like to know when the indian head tractor pullers association pull is. the one that is in ridgeland, WI. thanks for the help. luke
Chad
05-11-2003 09:50:29
 Re: Does anyone know when the ridgeland, WI tractor pull is? in reply to Luke Olson, 05-05-2003 08:57:25
It is Sunday night of Memorial weekend. I don't remember if it starts at 3600 or 4500 pounds and goes up. All the same rules apply, stock rpm's, no cut tires in farm stock classes. I think they give you 200 pounds grace on weight.
I go down just to watch it every year. Seems like Ridgeland draws in some stiff competition. Guys I pull against all year that do well, don't down there.
Good luck.
kevin m.
05-07-2003 19:52:52
it is normaly memoryal day weekend
T-puller
05-09-2003 15:11:15
 Re: Re: Does anyone know when the ridgeland, WI tractor pull is? in reply to kevin m., 05-07-2003 19:52:52
Anyone know the classes and weight of classes they run up there im wonting to come up there?
Steve
05-09-2003 17:14:13
 Re: Re: Re: Does anyone know when the ridgeland, WI tractor pull is? in reply to T-puller, 05-09-2003 15:11:15
It is a run what you brung and hope you brung enough pull. They usually start at 3600 pounds and go up from there. Later Steve
Dale
05-12-2003 13:30:44
 Re: Re: Re: Re: Does anyone know when the ridgeland, WI tractor pull is? in reply to Steve, 05-09-2003 17:14:13
The Indianhead Tractor Pullers Association pull in Ridgeland Wi. is on the 25th of May, Sunday nite at 6:00. Starting weight is 4000lbs.There are few rules other than general safety rules. After that when the regular ITPA pulls begin, all class rules apply. New this year: farm stock will only hook once, and all hooks are 20.oo. Dale.
Gump
05-12-2003 19:06:24
 Re: Re: Re: Re: Re: Does anyone know when the ridgeland, WI tractor pull is? in reply to Dale, 05-12-2003 13:30:44
Do they have a 4500, what safety equipment should a person have. Tire size limits? Manifold, block, carb rules?
Dale
05-12-2003 19:23:13
 Re: Re: Re: Re: Re: Re: Does anyone know when the ridgeland, WI tractor pull is? in reply to Gump, 05-12-2003 19:06:24
Gump, the classes are as follows: 4000, 5000, 7000, 9000,are all non-turbo, 11,ooo 13,ooo open:5000,7500,9000,Mod:5500, 6500, The only rules are general safety rules, drawbar height:20", after that ...no rules for this pull. At the rest of Indianhead sponsored pulls there will be specific rules for each class: farm, hobby, open,.Safety eguip. for this pull is always suggested, but not required, at THIS PULL ONLY!!!
