Gray Oil
Jason
05-05-2003 17:12:47
I recently bought an M to pull and I got it to run like a raped ape. The only problem is after i changed the oil(which was gray) and put in new oil, it too turned gray.It sat outside for a long time with no exaust pipe so i think water may have just ran in and contaminated it. Has any one heard of this? Or should i pull the head off? thanks for any help
Big Red
05-07-2003 16:40:50
 Re: Gray Oil in reply to Jason, 05-05-2003 17:12:47
The problem is no pipe on manifold, it will make oil gray overnight if it rains will also cause valves to stick. I had one pipe and muffler was their but when hood was removed pipe was cracked around manifould. Do not remove head until oil is changed and top of tractor is fully covered.
D PULLER
05-05-2003 20:48:38
Sounds like water is seeping in somewhere. Could be cracked head or block.
joe
05-05-2003 20:47:34
change oil one more time and if it's gray again then look for a bad head gasket or cracked head or block not a IH person so not sure if it's wet or dry sleave engine if wet could be sleave O rings
Mfarmallpuller
05-06-2003 22:21:58
 Re: Re: Gray Oil in reply to joe, 05-05-2003 20:47:34
M farmall's are drive sleeve, must be head or block leak
Mfarmallpuller
05-06-2003 22:23:36
 Re: Re: Re: Gray Oil in reply to Mfarmallpuller, 05-06-2003 22:21:58
Meant dry sleave, sometimes I just can't type, sorry (been having to write too many term papers lately)
redrev
05-08-2003 04:51:11
 Re: Re: Re: Re: Gray Oil in reply to Mfarmallpuller, 05-06-2003 22:23:36
It ain't you, it's the dang puter. They can't type and the can't spell very well, either. It's always the puter!
