High Compression Pistons?
Roger H. Brown
07-25-2001 08:47:52
Where can I find high compression pistons to fit a 1946 John Deere A earlier serial number? Much appreciate the help, I've been told high compression pistons will not fit in tractors with serial number prior to 584,000?
Mike in Mo
07-27-2001 06:10:29
 Re: High Compression Pistons? in reply to Roger H. Brown, 07-25-2001 08:47:52
Antique Engine Co. has pistons for your A. Phone number is 1-877-987-1118. I put late A/60 M&W pistons in a 1940 A and it worked just fine. That combo should yield about 6:1 compression, if you want more use the LP pistons. The only modification you might have to make is to grind the spark plug relief down a little more so the piston doesn't cover the spark plug at TDC. Good luck, Mike
Gman
07-27-2001 03:16:58
Roger try Hinrichs Repair Ph. 1-815-778-1900,that's where I get pistons for "G"s they are better I think than N.O.S. Pistons the skirt area is a little thicker. On the John Deere 70 Lp pistons are prone to crack in this area.Fine fellow to do business with,if I can be of any farther assistance post back Gman
