I Need A Distributor
BUDD
05-07-2003 16:25:28
Where can I get a Distributor set up for pulling in farm stock class for a 49 JD "A"? I tried Denny's, but they do not have any. He did tell me he could set one up for me if I furnish it.
THANKS BUDD
al
05-07-2003 19:30:17
 Re: I Need A Distributor in reply to BUDD, 05-07-2003 16:25:28
I have one for a G that was modified by Motec,will fit your A.
al murph128@hotmail.com
BUDD
05-08-2003 02:26:52
 Re: Re: I Need A Distributor in reply to al, 05-07-2003 19:30:17
Al; Thanks for your reply to my post. Tell me some more about this distributor you have. How much would you like to get from it? Does it have electronic ignition in it? Where are you at? How long sense it has been gone through? Is it the same Distributor that my 49 "A" would have from factory? Has the advance been worked on for pulling? I pull my "A" in farm stock class. It is bored out .125, head milled 1/4", head has been ported (some what) and polished with a "71" carb. I have 147 PSI at the plugs and I estimate 9 to 9.5 to 1 compression. In your opinion will this Distributor would with my needs and set up? I am currently running a Wico X Mag. Again thanks for your reply and info on this. I tried to E-Mail you but it would not work. I found that mine was not right in the original post either. My E-Mail is right in this post.
Bud Dawson Warsaw In.
