Fuel
G puller
05-08-2003 19:41:35
Where can I order some good fuel. High Perfromance Turbo Blue, Sinoco, what ever... open for suggestions.
JDGnut
05-12-2003 08:50:49
 Re: Fuel in reply to G puller, 05-08-2003 19:41:35
I couldn't get the www.vpfuel.com site to open.. but it might later.. IF they don't have a local distributor listed, call and see if someone in your area is selling the fuel..
JDGnut
Marvin
05-09-2003 22:32:11
Try your nearest fuel distributer. Many of them have a pump containing racing gas out back of their office. Also your friendly local airport is a good source of aviation gas. Just remember to bring an approved metal container.
G Puller
05-09-2003 14:59:35
I live in Wisconsin actually. Ill make sure to try the closest race track which is the LaCrosse Motor Speed Way. Thanks for the help.
Brandon
05-10-2003 20:22:38
 Re: Re: Fuel in reply to G Puller, 05-09-2003 14:59:35
A race track isn't exactly the best place to get racing fuel, unless you like paying alot. My dad drag races, and just gets his Cam 2 from a local Marathon station. I can't remember the prices, but I think the track had a much higher price. Try asking some local racers where they get their fuel.
Brandon
My Industrial John Deere website
My JD model 80 website
G Taylor
05-09-2003 08:04:55
Depending on the combination ,car pump gas maybe plenty. Extra octane beyond what is required drops HP as it's harder to ignite. For a long stroke, low rpm, hot running engine that's pounding along. The burn characteristics of aviation gasoline for radial engines is superior to Cam II or what ever meant for a 9000rpm small block.
Scott
05-09-2003 05:29:26
Not knowing where you are located is the first problem. If you are anywhere near Winston Salem, NC, try Hank Thomas Performance.
Scott
05-09-2003 05:30:24
 Re: Re: Fuel in reply to Scott, 05-09-2003 05:29:26
www.hankthomasperformance.com
randy hall
05-08-2003 21:43:20
i use cam two that i get from a guy that supplies sprint car racers. are there any roundy round tracks in your area? this would be a good place to look.
