Rods
Ohio H
05-15-2003 17:18:47
Need to find a conn. rod nine inches, center to center, or a four inch piston with a pin located two inches from the top of the piston. Need these for a C-169 with mild stroke. Anyone know of a part that fits these dimensions? Thanks.....H
dean
05-17-2003 19:34:29
 Re: Rods in reply to Ohio H, 05-15-2003 17:18:47
ford trucks with the int diesel motor 6.9 liter run a 4 in piston with a 1.9465 comp hgt. or more common pistons out of a wc,wd,wf,allis motor have 4 in bore with 2.315 comp hgt..if this is a little to much could turn excess off of dome of piston as they are pretty thick..easy to do in a lathe and these pistons are cheap and everywhere..hope this helps..dont have a rod book so cant help there.
Jason
05-15-2003 18:49:05
Check a GMC 302 V-6. They were a truck motor in the '50's. E-mail me if they will work and you have trouble finding any.
