Mag
uc
05-16-2003 10:38:51
how do you put a tack on a tractor with a mag
Mark
05-24-2003 08:16:03
 Re: mag in reply to uc, 05-16-2003 10:38:51
You can also get a tach that works off the alternator.I believe you can buy them at an A.C. dealer.
john
05-16-2003 15:15:28
Run it off the kill post on the mag, or if it doesn't have one, run a wire out the side off the points. As long as you use a tach for points type ignition and can figure out how many times the points open and close for every full cycle it should work. IE, on JD u may have to set tach for 4 cyl to get it to work on some of the 2 cyl tractors. Your cheap Wally World Sun tach should work on the mag.
John
Mfarmallpuller
05-16-2003 10:58:51
If you don't care to pay out the butt you can put a tach that runs off a sensor on the flywheel but they are pretty expensive.
