Denny's Parts (What's Wrong With Them?)
UNKNOWN
05-16-2003 11:19:11
Hey what is really wrong with his parts , Sure he likes to make lots of money and the parts probably aren't worth near what he charges for them, but hey, it is you idiots that buy them, What is wrong with trying to get rich off idiots
Albert
05-18-2003 08:59:18
 Re: Denny's Parts (What's Wrong With Them?) in reply to UNKNOWN , 05-16-2003 11:19:11
Once seen a DLTX51 painted all shiny black and a pretty Denny's tag on it.When installed it poured gas out.Broke the magic seal too and it looked every bit as old as is it was inside.Needless to say it was sent back.He gets over 30 dollars for a fuel shutoff when you can get the same ball valve and 3/8 line and inline filter at a local farm store for about 10 to 12 bucks.
Shutt30
05-17-2003 14:00:52
A fellow puller sent a carb that he got at a salvage yard off to get reworked for pulling. 3 weeks later he got his shiney fresh painted carb back. He installed it and tried to start his tractor. It wouldn't stay running unless the choke was on. Now frustrated he then broke the magic denny's seal on the carb and found not only was the carb full of corrosion and rust, but totally stock. He then conntacted denny's with some effort too finally get it cleared up. Not my story, just whatI was told.
Super IH Puller
05-16-2003 21:11:52
First the wheelie bars will not hold a jack test (example) Thanksgiving weekend pull in OH. Secondly $28 for a break away switch. they are $8.50 @ the part store.
supermpuller4
05-27-2003 19:01:15
 Re: Re: Re: Denny's Parts (What's Wrong With Them? in reply to mrs denny, 05-21-2003 15:39:54
Did you test the light front end too. Mine broke going through a small hole, another bent unloading from a trailer. I called you up Mr Denny would't come to the phone,didn't get anything but excuses from you. DONOT buy anything from the crooks at Denny,s..
Lloyd Powell
05-28-2003 20:01:29
 Re: Re: Re: Re: Denny's Parts (What's Wrong With T in reply to supermpuller4, 05-27-2003 19:01:15
Thanks for the info I was about to call and order parts. NOW I will use other source.
Super IH Puller
05-23-2003 08:48:52
Hey Mrs. Denny,
There was more than one tractor that had your wheelie bars on. It didn't matter which class they pulled in. I don't know the names of the pullers but they quit checking you bars knowing that they would bend. And I'm not talking about a tractor getting dragged off a track I'm talking about your bars! And your comment about driving to the parts store. It is cheaper than buying yours! I can drive the 3 mile to get it. What makes yours so special I'd like to know. It is not so hard to figure out that you don't need all the extra parts. Your advertisment is just as heavy as the one I got for under $10 And the cost of gas that it took was $1.59. Still all I see is savings$$$$$$$$. Your product is sent with wire cut and some wire connectors. Yea your company has good products but some things your paying for the little sticker that has your name on it. For example carbs and the HIGH FLOW SEDIMENT BOWL KIT. Again part store and hardware store 3 miles away under 15.00 priceless!!!! You folks need to go to the different stores to see for your self. Thanks and have a nice day my friend.
Undecided
05-16-2003 19:04:26
Dennys is good for certain things.If you dont want to screw around and make something or look for it at the local parts store,he is ok to deal with.Any tech support is another question.
Give him a Call
05-16-2003 14:38:14
Call him.. and TRY to talk to him... U'll figure it out...
KNOWN
05-16-2003 11:36:04
This is the kind of comment that sounds like Denny would make himself!!
BUBBA
05-18-2003 15:09:02
 Re: Re: Denny's Parts (What's Wrong With Them?) in reply to KNOWN, 05-16-2003 11:36:04
sOUNDS LIKE HE REBUILDS THE CARB'S AND WHEN YOU BREAK THE "MAGIC SEAL" IS WHEN IT GOES BACK TO THE WAY IT WAS BEFORE HE OVERHAULED IT, IS THAT MAGIC OR WHAT. YOU CAN HEAR GOOD AND BACK ABOUT ANYBODY. LOOK IN THE MIRROR BEFORE YOU OPEN YOUR MOUTH.
Hillbilly Hooker
05-18-2003 21:20:46
 Re: Re: Re: Denny's Parts (What's Wrong With Them?) in reply to BUBBA, 05-18-2003 15:09:02
The only problem i have with Dennys is that he is a crook!! I have found him to be a real a-hole. His wife is a real B;tch also. Just my opinion.
Hillbilly Hooker
05-21-2003 20:13:35
 Re: Re: Re: Re: Re: Denny's Parts (What's Wrong With Them?) in reply to mrs denny, 05-21-2003 15:44:16
Good to know that we agree on one thing!
Hillbilly Hooker
05-22-2003 20:18:44
 Re: Re: Re: Re: Re: Re: Re: Denny's Parts (What's in reply to mrs denny, 05-22-2003 14:01:40
you should know! I told you when you did me wrong that I would advertise for you all I could. Just doing my job. Have a nice day!!!!
ANOTHER INTERNATIONAL PUL
05-26-2003 20:09:14
 Re: Re: Re: Re: Re: Re: Re: Re: Denny's Parts (Wha in reply to Hillbilly Hooker, 05-22-2003 20:18:44
NO NEED FOR ANY X-TRA ADVERTISEMENT..DID BUISNESS WITH THEM ONCE....HAD SOME TROUBLE WITH A CARB. AFTER A LOT OF MONEY AND HEADACHE...SENT TO ANOTHER CO. AND HAD THE JOB DONE RIGHT....WILL NEVER USE DENNY'S AGAIN AND I LET ALL MY TRACTOR BUDDYS KNOW.
Kenny Chinsey
05-20-2003 05:06:34
 Re: Re: Re: Re: Denny's Parts (What's Wrong With Them?) in reply to Hillbilly Hooker, 05-18-2003 21:20:46
I agree with Hillbilly Hooker. Dennys just plain s;cks.
Krouthead
06-02-2003 17:38:42
 Re: Re: Re: Re: Re: Denny's Parts (What's Wrong Wi in reply to Kenny Chinsey, 05-20-2003 05:06:34
Sounds like Dennys stock just dropped!!!What about it Mrs Denny i.e. Martha Stewart?
There is a thing called the GOLDEN RULE!!
Which Dennys s;cks MR or MRS Denny?
