Front Wheel diam / Front end height???
al
07-27-2001 23:00:33
What's your opinion on lowering the front end through smaller front wheels? I can get correct drawbar height either way but was wondering if there is any advantage to dropping the nose?
10x30
07-29-2001 18:45:35
 Re: Front Wheel diam / Front end height??? in reply to al, 07-27-2001 23:00:33
yes lower front end is weight transfer,Ient to 14" tires on 1030 case and cant pick up the front at all
Dick
07-29-2001 19:28:16
 Re: Re: Front Wheel diam / Front end height??? in reply to 10x30, 07-29-2001 18:45:35
Yes you can go too far. When you go too far the bull pinion is so far down the front of the bull gear It has to lift straight up instead of walking up a slight incline. Or maybe your tractor has planteries for final drive.
SteveV
07-28-2001 13:42:15
I've often wondered that same thing. There must be an advantage since a lot of pullers do it. I think it changes the angle of the hook from the sled to the loop or clevis. As the angle becomes less in terms of degrees the sled pulls down more on the rear wheels which is an advantage for traction. Just my opinion.
Steve
