Spark Plug gap SMTA
Ed
05-19-2003 19:03:22
IM RUNING A 264 BLOCK WITH MW 5.75 BY 4.125 WITH 4500 VOLTS AND 111 OCT FUEL WITH AUTOLIGHT PLUGS, WHAT GAP SHOULD I RUN ON THE PLUGS
Mark
05-24-2003 07:50:20
 Re: Spark Plug gap SMTA in reply to Ed, 05-19-2003 19:03:22
Type of ignition was not listed but if you are running electronic with hot coil and amplifier box i.e.:MSD,Mallory,Jacobs,I would start at .045 and try it and go up from there.Pull your plugs after each pull you attend and inspect them,if you see any signs of high speed glazing,detonation, carbon fouling,or any other adverse condition stop and close them up .001 at a time until it clears up.Once you do that you then have a starting pint if you want to try a different heat range plug or a different plug make.It is a good idea to keep a record of this information forlater.
ASUPULLER
05-20-2003 17:20:44
I have a 500cid M-Farmall,with autolite plugs gaped at .080,,I run open classes at 30% over,and have yet to change the plugs,there are at least 30 pulls on them maybe more!,,I don't change them unless I have trouble with them.
Wide Front SM Puller
05-20-2003 13:21:03
I run a 281 c.i. super m with msd coil, 115 octane and 265 psi per cylinder. I run a 48 gap with autolite c-81 plugs, no problems, I also change plugs every 10th pull.
My 2 cents worth
Ed
05-20-2003 17:20:53
 Re: Re: Spark Plug gap SMTA in reply to Wide Front SM Puller, 05-20-2003 13:21:03
IM ALSO RUNING A LP 450 HEAD AND MY PSI GAGE GOSE TO 210 PSI AND WHEN I TEST THE PSI THE GAGE DONE A 360.NEED TO GET A HIGHER GAGE.AND I PUT A 806 BOTTOM ON MY SM CARB AND I PORTED THE TOP SM CARB,INTAKE MANIFOLD AND HEAD.TO MATCH THE 806 CARB
