Tire pressure for 14.9's
Farmall Boy
05-23-2003 12:49:00
What would be a good tire pressure for 14.9's on a 14 in. rim....pullin 5000 and 4500 with an m if it matters
Chad
05-24-2003 19:25:37
 Re: Tire pressure for 14.9's in reply to Farmall Boy , 05-23-2003 12:49:00
I run 10 psi in the 5500 and 6500 with a Farmall Super M. I check the ruts when I get done pulling to make sure the dirt was taken out flat-not oval or humped in the middle.
Jack
05-23-2003 13:04:04
Seen lots of them running anywhere from 10 to 13 psi with good results.
Jack (AZ)
05-29-2003 21:03:33
 Re: Re: Tire pressure for 14.9's in reply to Jack, 05-23-2003 13:04:04
Read somewhere that it doesn't gain much traction to go below tractor mfg. or tire mfg. recomendations. Most of the time this seems to be around 11 or 12 psi.
