HELP WITH 88 GOVERNORS
ANDY B
05-24-2003 21:19:16
CANT SEEM TO GET THE BUGS OUT OF MY GOVERNORS. (496 CUBES AT 2500 RPMS WITH STOCK GOVERNORS) IT WANTS TO SURGE AND ONLY HOLD ABOUT 2100 TO 2200 RPMS GOING DOWN THE TRACK. ANY GOOD IDEAS, THANKS ANDY.
EASY FIX
05-27-2003 17:26:00
 Re: HELP WITH 88 GOVERNORS in reply to ANDY B, 05-24-2003 21:19:16
Buy a stock super 66 governor and all your problems will be over! Maibach Tractor keeps them in stock for Mr. Gingerich.
1945RC60
05-27-2003 16:20:55
How in the h*** do you get 496 cubes out of an 88? Not trying to be smarta** but would reallly like to know. Don't worry, I'm not going to do it tomorrow.
SEVERAL OVER 600 CUBES
05-28-2003 18:25:03
 Re: Re: HELP WITH 88 GOVERNORS in reply to 1945RC60, 05-27-2003 16:20:55
600 + is the norm these days
Cody Adgent
06-01-2003 20:28:52
 Re: Re: Re: HELP WITH 88 GOVERNORS in reply to SEVERAL OVER 600 CUBES, 05-28-2003 18:25:03
Is that the average size of the engines that are laying behind people's shops with a huge hole in the side of them? Those are what I would call a disposable engine!
Goldsburg
05-28-2003 09:10:31
The question is not "How did you get that much?". The question should be "Why did you go that small"?
"Common" Open class 88 olivers are now OVER 500 cubic inches, with the bulk over them at 540 cubes or greater.
If you are going to the trouble to bore and stroke, why not do it to the max? You can always sort out induction system troubles later...
Regards,
Goldsburg
P.S. 180 HP to 190 HP will now let you finish near the bottom of a "National" Div 4 or 5 Open antique class.
Littlemotors
05-27-2003 16:36:16
It is done by poking and stroking and inbreeding!!! Sounds like fun doesn't it?
Cody Adgent
05-25-2003 20:12:14
how big of a carb are you running? Try lightening the weights up and running less spring pressure. Sometimes you can fix them by adjusting the screw in the front of the govenor housing. My 3.5 cents!
