F-12 wheels on a H
Dan
05-25-2003 19:28:33
I would like to lighten up my Farmall “H” by installing different rear wheels (for pulling). I’ve been told that the spoke wheels on a Farmall F-12 will fit a H. I have found a pair; they are the steel center type with the flat spokes. Is there anything that I should be aware about these wheels? I will have to cut them and weld on a set of rims.
Thanks for any help.
Dan
Mike R
05-25-2003 21:00:49
 Re: F-12 wheels on a H in reply to Dan, 05-25-2003 19:28:33
Thay should work fine just make sure thay are not craked around the hole where you spread them to remove from tractor. Mike
