Oliver 880
HB
07-30-2001 07:58:49
I pull an 880 Oliver have done some oversize valve
work to the engine. What else can I do to give me
more power and still look stock? I'm tired of the
JD and Farmalls beating me.
Lee
07-31-2001 12:42:17
 Re: Oliver 880 in reply to HB, 07-30-2001 07:58:49
Oliver 1650 manifold a carb will help. Will bolt on with out making any changes other than air cleaner hose. Dry air cleaner would help if rules permit.
Tyler
07-31-2001 17:20:59
 Re: Re: Oliver 880 in reply to Lee , 07-31-2001 12:42:17
A 1650 cam will also liven up your 880. We also run a straight pipe through the hood with a K&N air cleaner on the end. Through the oil bath assembly away if your rules allow.
Tyler
John
08-28-2001 19:34:52
 Re: Re: Re: Oliver 880 in reply to Tyler, 07-31-2001 17:20:59
I pull A 770, couldn't agre more...Ignition & Carburation!
770
07-31-2001 19:18:38
two words...ignition and carburation.
