53 SM power boost
muleskinner
05-28-2003 20:22:24
PLEASE,, someone tell me how I can get about 25 to 30 more HP from my SM. You guys are pullers so I know you have the know how, please pass a little on to me, I don't have a lot of money to do it. thanks
Jack
05-29-2003 13:56:43
 Re: 53 SM power boost in reply to muleskinner, 05-28-2003 20:22:24
Its hard to do but if you could find a propane head for about 500.00 and work it good,that would be a substantial increase.Then send the carb off and install an electronic ignition.These things should wake it up some.Happy pulling.
TimC
05-29-2003 09:29:10
Not being familar with the farmall head if it has a combustion chamber you could mill the head to raise the compression and have the valves worked at the same time to help out some. You could open up the plenium in the intake (not the runners) to give it a little more available charge. If you could induce swirl into the cyl filling that would help a lot but it takes a lot of experiance to know how to do it and money if you arn't able to do it your self. Regrind cam or change the rocker arm ratio or both. Adjust timing to whatever works the best.
