Rim size for a 13.6 tire
Dan
05-29-2003 17:44:53
I need new rims for my Farmall H that has good 13.6 x 38 tires on it. I use it for pulling, what would be the best rim size for the 13.6 for pulling?
Thanks.
Dan
slow mo
05-30-2003 14:43:46
 Re: Rim size for a 13.6 tire in reply to Dan, 05-29-2003 17:44:53
I ran 1 set on 12 and my other set on 14s.I would out pull same guys I pulled with every week by 10-12 feet on 14s.Also jumped to top end of my next class 5500. Won a couple.So a most of groups in my area put a new rule in to stop me and others from doing that.To keep the class closer.So now Iam back on my 12s.
Jim M
05-30-2003 10:07:42
Iwould check the rules for where you pull first. Some limit it to the size the tire was designed for which is 12".
Jack
05-30-2003 09:55:46
14's are a common size and would make them 13.6's flatten out nicely.If you wanted bigger tires later you could still use the 14's for 15.5's or 14'9's.
wider
05-30-2003 07:35:11
i would use a 14 in rim, I have a 15 in on my 13.6 now and it is a little too wide.
