MSD hookup with the electronic ignition
Mike F
06-04-2003 18:08:35
I am soon going to rewire my oliver super 88 and can anybody tell me the correct way, or best way, to hook it up to my msd #6 box, the box says the white wire goes to the points, but which wire of the two at the distributor, thanks in advance. Also any advice on kill swithces?
Stroker G
06-05-2003 21:29:47
 Re: MSD hookup with the electronic ignition in reply to Mike F, 06-04-2003 18:08:35
Are you from Portersville?
jcm
06-05-2003 16:03:13
when i hooked up my 6a box msd said to wire it according to the wire diagram of 'amplifier' when a pertronix is in use ....works fine.
FB
06-05-2003 16:00:47
almost everything except the ground wire goes to the + end of the distributor
FB
06-05-2003 16:24:12
 Re: Re: MSD hookup with the electronic ignition in reply to FB, 06-05-2003 16:00:47
OOOPPS! meant to say coil instead of dist.
Brandon
06-04-2003 19:24:15
You should be able to find a wiring diagram on the MSD website. I found one on there back in the winter.
dave
06-04-2003 19:15:37
mike look on the directions for a pertronix electrronic ign. on back page of msd instruction book.
