4.1 HOLSET TURBO
REDMAN
06-07-2003 06:13:50
I'VE BEEN ASKING EVERYONE ELSE THIS QUESTION AND GOT SEVERAL DIFFERENT ANSWERS,MAYBE YOU CAN HELP.
I HAVE A 4.1 HOLSET TURBO WITH G WHEEL.CAN I TURN THIS CHARGER WITH A 436 C.I. ENGINE,I SPIN IT AT AROUND 6000 RPM.IT IS A COLUBUS DIESEL TURBO WITH A AIR-RESEARCH EX. HOUSING.DON'T REMEMBER THE NUMBER BUT WAS THINKING A 100 HOUSING,WHAT DO YOU THINK?TRIED IT LAST YEAR,BLEW CROSS-OVER PIPE RIGHT OFF,MAKING O-RING FITTINGS FOR CROSS-OVER.
THANKS FOR ANY ADVISE.REDMAN
Gunslinger
06-12-2003 12:32:58
 Re: 4.1 HOLSET TURBO in reply to REDMAN, 06-07-2003 06:13:50
Redman,you said the magic words,call Columbus Diesel Supply and ask Mark Massey.If any one can tell you,he can.He has probably forgot more about turbo's than the majority of the people on here will ever know.
tim
06-07-2003 13:52:56
There are a lot of variables that come into play but I would think that 4.1 is getting pretty big for a 436, we are running a 4.1 on a 540 right now with good results. You will probably need a solid mechanical fastening system (turnbuckle etc.) to keep your crossover together if you get that turbo spinning at 6 grand. Good Luck.
REDMAN
06-08-2003 08:27:15
 Re: Re: 4.1 HOLSET TURBO in reply to tim, 06-07-2003 13:52:56
THANKS TIM I THINCK THAT THE ONLY WAY TO GET THE ANSWER FOR THIS ONE IS GOING TO BE TO TRY IT AND EXPERIMENT WITH IT.THANKS FOR THE INPUT.
